Jack Bauer uses the reverse diode and resistor in parallel with the normal gate drive resistor.
I think that he uses the UF4007 diode (ultra fast) and a 15 ohm resistor in series
and that pair is then placed in parallel with the gate drive resistors that you already have.
Paul discussed it here
http://ecomodder.com/forum/131476-post2353.html
