diode and resistor combo
okay, i'll give it a go with the diode you specified and 15ohm resistor.
now i do have a question which comes about coz i don't have a full grasp of what i'm doing.
when i reduced the resistance by putting the other resistors in parallel with the original gate resistors it brought the total resistance down a WHOLE lot.
if i place the series combo in parallel with whats there already, i am working on the assumtion that as long as the combo is oriented in the correct direction, the resistanc ewon't drop any further (except in the direction i want yes?)
I will be using a small diagram i think i got from jack bauer to make these,
any suggestions or corrections are more than appreciated,
and Paul
the controller ROCKS!!
imagine, a controller that doesn't want to blow itself up...how novel!
