Old 07-20-2010, 02:58 PM   #5 (permalink)
EdKiefer
I have some limited experience with stand alone units . The factory changes spark advance a lot in most cars some goes to 40 deg at low speed/ part throttle vacuums .
On after market though on many units if you try to do same things you can run into transit knock advance issues , its like the stand alone is not as fast ECU or not enough break points . Either way many don't go high on part throttle advance so transition to load is smoother. another way to think of it is pre ECU control , think of the vacuum advance unit on distributor and running with it off , thats another way to look at it .
The Following User Says Thank You to EdKiefer For This Useful Post:
Meph (07-20-2010)
