no EGR, JDM engine. I have a vac/boost gauge int he car and the values between my MAP sensor and boost gauge are comparable. The X axis is all in PSI, the conversion is somewhere around 2.03, I can talk in -psi or in-Hg, but not many people use -psi.
the incitements are in 500 rpm between maps with the ecu averaging the values in between. Someone is running 38 degrees apparently, so 35 seems reasonable, Ive run 32 before. Im not really experienced with detecting ping, ill ramp up slowly, eeping a keen ear open, I've installed multiple mufflers ont he car to reduce noise, its still loudn with a lot of road noise but i think I can still pick it out.
Thanks a lot for participating in the discussion everyone, ive posted the question on 4 different forums without a responce at all till now
