...regarding the "flathead" exhausts (I had a '53 Victoria), you failed to mention or show that the two left and right exhaust ports were connected by a cross-over piple that went over the front of the engine, above the water pump, and connected the right- and left hand exhaust manifolds together so the exhaust from BOTH sides went by one side before it went back through the single exhaust header pipe and then to the muffler.
