As long as you are able to produce & store more power than it is needed to make the vehicle move, it should work. I haven't done the math, but I doubt those high output amp will be able to pump enough juice to move the vehicle forever. Do you do some math, and did you include any loss (drag, friction) in them ?
Maybe using a load of solar panels with those HO alt. would give enough power to move on the flat, but what about hills ?
I don't know. Seems to good to be true.
