Old 07-23-2010, 09:49 AM   #26 (permalink)
Arragonis
The PRC.
Originally Posted by Patrick View Post
So why does the clutch pack burn up if you coast in neutral? Doesn't it run in an oil bath?
I think its the centre diff or something which lunches itself if only one set of wheels (front or rear) is turning. Similar advice is never to tow a Subaru AWD with wheels on the ground - i.e. use a flatbed.
There is a 2WD version of the Imprezza so the gearbox could be swapped leaving the rear shafts in place and then drive that assembly seperately as shadetree tapped.
Starting to get expensive though.
