Old 07-23-2010, 09:17 PM   #20 (permalink)
EdKiefer
What ECU controller are you using ?
So this is basically first real running with it on .
Maybe you could post a higher rpm map, like 4k rpm so we can see how timing is for a rpm were light load to full boost would enter in (assuming 4k rpm is able to get max load ) .
