Old 07-24-2010, 01:13 PM   #5 (permalink)
C3H8
insane in the propane
Cloud Car - '96 Dodge Stratus ES
90 day: 39.15 mpg (US)
the only place that sells ethanol free gas in florida i have found is certain sunoco's. the problem is that the gas is 110 octane and costs about $8.00 per gallon. sort of defeats the purpose of it. although the 110 works great in my banshee atv!
96 stratus "es" v6 auto-stick
supplementary propane injection
injector kill switch, alternator kill switch
Charging system voltage increased to 15.5V
secondary and tertiary 12v batteries in the trunk
on-board battery charger
lights converted to led's
potentiometer controlled tps for ign timing
welded straight pipe in place of cat-cons
removed egr
3 inch body drop
90psi fuel rail & -50% low volume injectors
run 15% diesel 85% gas
