Yes, lawn edging from HD. $7 and change for 20 feet. There is no need for detailed mounting pics, as it is simply screwed in place with sheet metal pan head screws. The nice thing about this edging is it has a lip on the edge that covers the screws installed. Simply held in place and drilled through the edging and plastic bumper. Installed screw under the lip of the lawn edging and the mounting is quite secure. At the wheel well openings, just cut the top and bottom where the lip and round part are and fold it around the edge of the opening. You can push the bottom in or out to get the look you want, then screw in place. I may add a brace in the center, as it does have a slight curve there but I am hoping the sun will straighten it out. Another pic.
