07-25-2010, 11:15 PM
#30 (permalink)
points away from the cat
Originally Posted by Daox
I also took it for a drive to test the load. I would to up to 94 for me at WOT in 2nd gear.
94% calculated load AT WOT in 2nd with a speed density system points us away from the cat converter being clogged as
clogged cat raises MAP which would max out calculated load at 100%
this is kinda hard to do without test equipment test results from
1000 miles away
how about
driving the car with Vacuum gauge connected and under the wiper as you drive
at cruise at about 45 mph in 5th .
along with calculated load from the scan tool at the same condition .
