Old 07-26-2010, 02:27 PM   #195 (permalink)
Dr. Jerryrigger
Dr. Jerryrigger's Avatar
The Sh*t-Box - '99 Subaru Impreza Outback Sport
90 day: 27.81 mpg (US)
Originally Posted by jdgFirefly View Post
If you want to regulate your power output you only have to add a control valve just before your steam motor. The unused steam will only build up pressure in the boiler until its needed.
If a low mass / flash boiler design is used than a separate tank may need to be added just for storing pressure.
The boiler can only hold the pressure as long as it can maintain temperature so adding insulation may help it hold pressure for longer, if that becomes a problem.
I was imagining a flash boiler thus far, but greater pressure holding capacity would be useful. It adds a lever of danger, as just about any energy storage method does.
I'm thinking that it will be quite complicated and or expensive to regulate the steam flow, in comparison to regulating the water entering the system. Just a thought. A well insulated, and beefy flash boiler could potentially hold heat for some time, but it would be nice to not add 300kg to ones car... the water will likely weigh quite a lot already.
