Old 07-26-2010, 05:09 PM   #3 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
In winter you can use whatever sunlight is available to help warming up the car's interior.
Or you could block the sunroof from the inside to minimise heat-loss from your warmed-up interior to the outside world.
In summer:
It'll help a bit to block the sun from the inside.
It'll help a lot more if you block the sun from entering your car through the glass : put the sunblock on the outside of the car.
(Maybe using the roofrails ? If you don't plan on deleting them, that is.)
