So I'm working on a solution to the pizza pan wheel cover problem. That being: there is no easy way to make them stay on. The plan so far is to drill holes in the pizza pan and run bolts through into my soon-to-be-extended lug nuts. A barrier is that I can't find lug nuts that are long enough. I need more than three threads showing. Has anybody been able to find 12mm x 1.5 lug nuts that are open ended and quite long?
