Old 07-27-2010, 04:34 AM   #2 (permalink)
SentraSE-R
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Hi ChazinMT,
Your education is about to start, and you're going to think my answers are extreme. They may or may not be extreme, but they're what will give you the best mpg.
First, forget about going over the speed limit. 5 mph over to 5 mph under is if you want your average speed to be slightly less than the speed limit. If you want best mpg, use the posted speed limit as your upper delta point, and 10-15 mph under the PSL as your bottom delta point. On a highway with PSL >55 mph, I use 60-62 mph as my upper pulse speed when there are cars around, and sometimes only 55 mph. When I set my cruise control for a highway cruise, it's at 50-55 mph. My SE-R gets 26 mpg at 72 mph, and 38 mpg at 55 mph. My xB gets 32 mpg at 70 mph, and over 40 mpg at 55 mph. Your Civic will behave similarly.
Then there's how much throttle and which rpm range to use. 75% throttle doesn't mean that. It means 75 LOD on your Scangauge, and it's moderately brisk in my SE-R, but pretty light on my Scion and your Civic. Your best acceleration for fuel consumed comes from your Brake Specific Fuel Consumption curve, but for most 1.5 to 2.0 liter I-4 engines, you start your pulse at 1500 rpm, and end it around 2000 to 2200 rpm - well below your variable valve actuation.
For hills, lightfoot your way up them, drop speed at the top, and enjoy the free coasting down them. When they're steep enough that you need to scrub off speed, DFCO down them in gear, and you won't use any gas.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
The Following User Says Thank You to SentraSE-R For This Useful Post:
ChazInMT (07-27-2010)
