Originally Posted by some_other_dave
ATF is much thinner than gear oil, do not use the Syncromesh in a transmission that is spec'ed for ATF!
-soD
What he said! Never put ATF (Automatic Transmission Fluid) in a manual transmission! You should be using just 10W-30 motor oil or something similar.
