Old 07-29-2010, 08:54 AM   #11 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Originally Posted by Quasimoto View Post
Putting premium gas in anything but a high compression engine is just a waste of gas and money. I does absolutely no good, since it needs the higher compression to ignite the higher octane fuel. Stick to regular gas and save your money.
It's not about the higher octane, it's the lack of alcohol as alcohol burning engines have different needs then gasoline burning engines, yes it will "work" but it will also work to dump a small amount of diesel in to a gasoline engine, not the best idea but it will work, veggie oil would almost be a better idea then alcohol.
