Old 07-29-2010, 12:00 PM   #20 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
You have the right shape, although the closer you can get to a knife edge, the better. I would not use a bumper, too heavy.
My next tail is going to be based on a trailer hitch receiver, with a tee shaped square tube insert, probably a plywood body, although there might be some coroplast used on it too.
If you build it right, i would guess that you can expect a 20% to 30% improvement in FE.
Nissan Versa Aeromods
