Old 07-29-2010, 12:14 PM   #9 (permalink)
C3H8
insane in the propane
Cloud Car - '96 Dodge Stratus ES
90 day: 39.15 mpg (US)
Originally Posted by Funny View Post
Hmmmm.... A propane powered Stratus.... That would be interesting to see.... how do you intend to implement this? Are you going to swap out the ECU for something like a Megasquirt? It will be an interesting build and I look forward to seeing what you can do with the money you saved just buying the car!
Hi, I don't intend to implement this, because I had finished version 1.0 of the injection a month ago. i'll do a little write up about it in a few days when i have enough time. I will also grab some pics so everyone can see the setup.
96 stratus "es" v6 auto-stick
supplementary propane injection
injector kill switch, alternator kill switch
Charging system voltage increased to 15.5V
secondary and tertiary 12v batteries in the trunk
on-board battery charger
lights converted to led's
potentiometer controlled tps for ign timing
welded straight pipe in place of cat-cons
removed egr
3 inch body drop
90psi fuel rail & -50% low volume injectors
run 15% diesel 85% gas
