Old 07-30-2010, 09:13 AM   #3 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
You won't see any fuel savings by alternating between heavily loaded and moderately loaded. You have to alternate between heavily loaded (at a minimum of RPM) and engine off, or nearly off.
Now that you've added a 4kW accessory load, I think you'll need to switch from P&G to DWL. You'll also want to drive slightly faster to get there sooner, because the sooner you get there, the sooner you can shut off the A/C.
The Following User Says Thank You to RobertSmalls For This Useful Post:
hummingbird (07-31-2010)
