Old 07-30-2010, 05:44 PM   #3 (permalink)
C3H8
insane in the propane
Cloud Car - '96 Dodge Stratus ES
90 day: 39.15 mpg (US)
yeah, 3 minutes is what it takes from cold start and idling.
and yes if you start driving right away it will change over quicker. but a lot of people like my self tend to let the engine idle for 20-30 seconds after a cold start to give things a chance to start working, and the oil a chance to circulate before putting load on the engine.
96 stratus "es" v6 auto-stick
supplementary propane injection
injector kill switch, alternator kill switch
Charging system voltage increased to 15.5V
secondary and tertiary 12v batteries in the trunk
on-board battery charger
lights converted to led's
potentiometer controlled tps for ign timing
welded straight pipe in place of cat-cons
removed egr
3 inch body drop
90psi fuel rail & -50% low volume injectors
run 15% diesel 85% gas
