Old 07-31-2010, 12:38 AM   #14 (permalink)
mwebb
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
NO
Originally Posted by daring4 View Post
In a related question can you apply resistors to the air intake temp sensor to decrease fuel use in normal driving? Sorta like lean burn for OBD1?
NO
if you DECREASE voltage by DECREASING resistance the ECM will repond by
RETARDING ignition timing
which will REDUCE FE and INCREASE emissions.
these are negative temperature coefficient sensors
High resistance and high voltage = cold
low resistance and low voltage = hot
The Following User Says Thank You to mwebb For This Useful Post:
daring4 (08-03-2010)
