Originally Posted by Funny
I believe I read elsewhere in the forums that 10 degrees was the ideal to shoot for. After that the air doesn't "stick" and you get turbulence. If you "have" to have it end at the top of the tailgate, make it an arc and not a plane. This is in congruence with what SVOboy posted .
do you think this would work? not sure if it is too planey..
http://www.hillbankmotorsports.com/p...ducts_id=10652
