So this one should blend a bit better but it will require relocation of rear lights (since I've no idea on how to shape acryllic sheets or stuff like that). Rear lights are easily removed (held on 2 bolts) and I should have no problem lengthening (?) wiring. At the moment parts are floating in the air but that's not a big deal...
I'm not sure about mounting method for fender skirts and the pink part might be a challenge in this setup. I can't make these parts any bigger since my trunk is quite small and it's supposed to hold some luggage too.
