C3H8, that is an interesting screen name. Isn't that the molecular formula for propane?
I would suspect adding the propane changes things up a bit. And changing things up a bit changes the known rules concerning modifications, and considering your astounding fuel economy, who can deny your knowledge? Of course, I must ask, since others will, do you add the gallons of propane used into the amount of gas used? Otherwise, your mpg figure would be off quite a bit.
 RIP Maxima 1997-2012
Originally Posted by jamesqf
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
