not sure if I understand correctly. But you are jumping the pins to turn on the IMA system, but the car is still off. So if those systems are running from the 12v battery while the grid charger is charging, would it run down the 12v a little bit from the long overnight charge? or am I missing something. Maybe the IMA computers dont use that much power to run down the 12v ?
