Old 08-01-2010, 09:04 PM   #175 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
As pictured above, yes, it drains the 12V battery. That's okay if you're grid charging the 12V nightly, but the right way to do it is to run the BCM and battery fan off an AC->12VDC power supply. Maybe a toggle switch on the battery fan, set to "off" for winter.
