Old 08-02-2010, 02:14 PM   #44 (permalink)
some_other_dave
If you like that, go with it.
For best MPG, use the lowest weight that is called for in the owner's manual for the car the engine came out of. I suspect that's either 5W20 or 0W20. A synthetic (or quasi-synthetic like Mobil 1) oil will probably cause a little less friction and pumping losses, and so contribute microscopically to better fuel economy.
For major MPG gains, though, you need to change the way you drive. I'm averaging about a 50% improvement since I started driving for economy.
-soD
