Old 08-02-2010, 01:17 PM   #57 (permalink)
3-Wheeler
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by euromodder View Post
That's normal for a trailing edge on a classic airfoil.
The upper and the lower airflow must meet up with as little turbulence as possible, so the angle between both flows is reduced when the flow reaches the trailing edge - both airflows are lined up.
On laminar flow and supercritical wings, you'll see "the circle" continuing on top, while the airflow line-up happens through an S-curve on the underside....
Hi Euromodder,
Yes, the bottom side of this airfoil is designed to create more lift. I'm after minimizing air drag, so the bottom "S-curve" may not apply in our road-going designs.
I still think that the streamlining airfoil shape from 70% to 100% needs some "adjustment".
Your airfoil still curves even if it is slightly, over that last portion on the top side of the wing.
Jim.
