Old 08-02-2010, 10:08 PM   #48 (permalink)
suspectnumber961
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
I've done the CHT sensor and TPS (throttle position sensor) on an '86 Nissan 720 4x4.
I have 2 rheostats in the dash and a switch also on the CHT sensor.
I notice that in warmer weather I can leave the CHT switch "on" and get a good start...in colder weather...it's more difficult to start.
The TPS mod will allow leaning the engine out to the point of reduced power.
I also run an EFIE at 200 mvs....seems to allow the O2 to cycle more easily than with no added mvs.
I don't believe I've documented an mpg gain though. I was having several other tuning/electrical issues with this truck and eventually I put things back to stock...thinking my messing around was the problem...when I noticed an increase in power.
Since I have the rheostats in the dash I can adjust things at will....now running at about 1/2 the LEAN setting I once ran.
What I am messing around with on my wagon is a a fuel vaporizer that has indications of both improving power and mpg....but I really haven't been able to finish testing it....having issues with the gas valve closing up and not allowing gas to vaporize.
Since I can lean the truck down real well...I eventually want to test a fuel vaporizer on it.
Here is some info on the subject:
http://www.nonags.org/members/nijqk/Sensor_mods.doc
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
