Old 08-03-2010, 11:44 AM   #2 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
As far as lubrication goes the minimum level is a matter of whether the oil sump sucks in any air while the engine is operating. Other things need to be considered though. Oil also acts like a coolant to some degree. Less of it means it will get hotter because it will spend less time sitting in the pan cooling off. The hotter it gets the sooner its lubrication properties will break down.
