Old 08-03-2010, 02:37 PM   #9 (permalink)
Matt Herring
Matt Herring's Avatar
Bone's 2010 Prius - '10 Toyota Prius Black
90 day: 56.78 mpg (US)
Originally Posted by bwilson4web View Post
Hi,
I trick I picked up over at PriusChat is to use EV to suppress ICE warm-up until you can get to a downgrade. Then use "D" or 10 mph to leave EV and let the ICE run while rolling down-grade. If you can go down-grade at a fairly slow speed, you'll take a big chunk out of the 'throw gas at it' warm-up.
Bob Wilson
I am able to use this trick rarely on a day to day basis but have been able to take advantage of it once in a blue moon.
On a day to day basis I commute 11 miles to and from work. No declines at either start point. And...typically I use heavy EV on the tail ends of my commute so the next time I start the car I'm at 2-3 bars and not EV-available.
When I am able to use it is on non-commute trips...especially when on highway trips when my SOC is higher. I probably have a chance to use the trick about once a month.
