Old 08-03-2010, 04:29 PM   #10 (permalink)
Frank Lee
Jyden: you have no, and cannot obtain, any proof of that.
In fact I have read from the manufacturer that they do NOT recommend always topping off to the full line. Their position is to NOT add until the level drops down to the ADD line.
Now, one possible reason for rock's observation is that when at the full line his engine has what is called windage, which is caused by the crankshaft physically dipping into the oil and whipping it around. Windage is bad not only because it takes horsepower; it whips the oil into an aeriated froth which then does not do as good a job at providing a lubricating film.
Go ahead and run it down to the add line. Or even start things off at the add line. It is possible to successfully run engines below the add line too as the drag racers have found out but for peace of mind I wouldn't go there.
