Old 08-03-2010, 07:27 PM   #11 (permalink)
Patrick
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
Too much stopping. Mount it to roof, cut hole in roof around the perimeter of the sign base, attach raise/lower mechanism and also self-actuated sliding cover for the hole.
There you go. Or if you have a sunroof, stick it just behind the sunroof opening. When out of range of the boss, open sunroof, reach up and remove sign, then close the sunroof. Voila!
