Old 08-03-2010, 11:58 PM   #10 (permalink)
C3H8
insane in the propane
Cloud Car - '96 Dodge Stratus ES
90 day: 39.15 mpg (US)
Those drawings of wings are airfoils that are intended to create lift, so that low horsepower airplanes can fly. You do not want a shape like that because you do not want lift in a car, nevermind an eco car.
A better shape would be that of a teardrop, or a tuna fish. (not a tuna fish can though).
96 stratus "es" v6 auto-stick
supplementary propane injection
injector kill switch, alternator kill switch
Charging system voltage increased to 15.5V
secondary and tertiary 12v batteries in the trunk
on-board battery charger
lights converted to led's
potentiometer controlled tps for ign timing
welded straight pipe in place of cat-cons
removed egr
3 inch body drop
90psi fuel rail & -50% low volume injectors
run 15% diesel 85% gas
