Old 08-04-2010, 11:36 AM   #16 (permalink)
C3H8
insane in the propane
Cloud Car - '96 Dodge Stratus ES
90 day: 39.15 mpg (US)
Originally Posted by Patrick View Post
I didn't mean to suggest that the car should be shaped like that. I was just showing that as the angle increases the area of separation does too, which increases drag. The second shot of the airfoil (when it's at a high angle of attack) is similar to the angle of the rear portion of the beetle and the flow is almost completely separated.
i understand, but i think that using an airplane wing shape as an example is not so good. one of the main ways a wing gets lift is through the difference in speed between the air passing above the wing, and the air passing below it. on a beetle, or any car really, i would guess that the air passing below the car is minimal, compared to the air going over the top. that is why i think an airplane wing is a bad example.
although airplane wing shape is still probably better then a brick as far as cars go.
there are some smart cookies on this board. why don't you guys apply you're knowledge to designing a combustion chamber, or a fuel efficient cam for the metro engine? seems to be to be a better use of these talents.
96 stratus "es" v6 auto-stick
supplementary propane injection
injector kill switch, alternator kill switch
Charging system voltage increased to 15.5V
secondary and tertiary 12v batteries in the trunk
on-board battery charger
lights converted to led's
potentiometer controlled tps for ign timing
welded straight pipe in place of cat-cons
removed egr
3 inch body drop
90psi fuel rail & -50% low volume injectors
run 15% diesel 85% gas
