Old 08-04-2010, 03:26 PM   #28 (permalink)
SuperHatch
Civic - '99 Honda Civic CX
90 day: 37.39 mpg (US)
Originally Posted by C3H8 View Post
What are you talking about? what relief valve is there for excess oil that dumps it anywhere but right back into the oil pan? The oil pump and oil filter are the only things with relief valves in the oiling system. And they dump excess oil right back into the oil pan, to be re used again. Do you mean the positive crankcase vent? "pcv"?
The relief valve in the pump dumps the excess oil back into the pan.
The relief valve in the filter simply allows the pressurized oil from the pump to bypass the filtration media, but it is still pumped through the engine. This is a safety feature to prevent oil starvation due to clogged filters. Dirty oil getting to the engine is better than no oil at all.
Other than that I have to agree with everything else you've stated in this thread.
