Old 08-05-2010, 07:46 AM   #3 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
I have a drive by wire accelerator and I suspect that it is nothing more than a potentiometer on the pedal end, which means that the throttle is controlled by the changing voltage drop on the throttle end. By tapping into the connector at the pedal, I think an arduino or other processor could simulate voltage levels to control the throttle by using pulse width management.
Nissan Versa Aeromods
