Old 08-05-2010, 03:29 PM   #152 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by mwebb View Post
60 volts ? on the supply side ?
is the car direct injection ?
where does it get 60 volts from ?
My engine is a direct injection turbodiesel.
From Big Bang Theory: Direct Injection Diesel Tech:
The injectors are opened with a peak voltage of 80 volts and a peak current of 20 amps. This initial opening phase is extremely short - only 0.3 milliseconds. A holding voltage of 50 volts is then used to maintain the injectors' open position. These very high voltages are obtained by using capacitors within the ECU - the ECU charges these up by sending electrical pulses to the coils of the injectors that aren't working, with the resulting induced voltage enough to charge the corresponding capacitor. Weird but it works!
