Old 08-06-2010, 01:10 PM   #2 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Mods done to the car so far :
  • Roofrails not fitted (10/2005)
  • Michelin Energy Saver LRR tyres (1/2009)
  • Tyre pressure gradually increased from 2.3 bar / 33psi to 3.0bar / 43.5psi
  • Added Cruise Control (4/2010)
  • Weight reduction : 35.8 kg / 78.9 lbs (8/2010)
    1. removed temporary spare tyre: 15.0 kg / 33.1 lbs
    2. removed jack: 2.3 kg / 5.1 lbs
    3. removed rear mats 0.9 kg / 2 lbs
    4. removed luggage cover: 8.0 kg / 17.6 lbs
    5. removed assorted junk: 2.1 kg / 4.6 lbs
    6. removed extra container of windshield washer fluid: 5.0 kg / 11.0 lbs
    7. filling windshield washer reservoir only halfway: 2.5 kg / 5.5 lbs
  • ScanGauge2 (08/2010)
  • 90% upper grill block (8/2010)
  • Volvo Libra aerodynamic 16" wheels, adding 13.6 kg / 30 lbs (9/2010)
Last edited by euromodder; 09-08-2010 at 06:34 PM.. Reason: More mods, more pressure
