Old 08-07-2010, 10:12 AM   #6 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Arragonis View Post
What is the gearing in the V50 1.6 Diesel, is it quite long - 6 speed or 5 ?
The 1.6D has a 5 speed box.
The gearing is fairly short - the DrivE versions have a longer gearing.
Although the weight loss is quite intense the V50 is pretty heavy as standad
Officially, it's 1375kg / 3031 lbs, including a "standard" driver (75 kg/165 lbs) and 90% fuel, but I plan to have it weighed.
so the overall gain probably isn't all that much.
Well, combined with my own weight loss, and only filling up halfway, It'll have 5% less weight. That should start to have a small effect.
You could think about taking out the reat seats if you are serious about less weight.
At the moment, I think that's still a bit too extreme.
Keep an eye on the DPF with short shifting, I have read it can clog up. An occasional 'full beans' blow to clear it out may be worthwhile
I usually have to gun it on the short on-ramps of the motorway.
But I'm already keeping an eye on the DPF as I didn't have it replaced at 120.000 km
It's still OK, so no need to swap it out.
I can get the average MPG on Mrs A's Octavia estate (2.0 litre) to read 60+ (UK) around town, I'm sure I could get it more on a run but I'm not allowed to drive it that far...
... let alone mod it
