Old 08-08-2010, 10:25 AM   #7 (permalink)
jackbauer
jackbauer's Avatar
Nice to know i'm not totally mad I have no problem with them using an accessory battery as with the key off the traction pack will (should) be offline so it picks up housekeeping loads. But why not a deep cycle gel or agm at the very least?? Or ideally a small lithium pack? Even my ultra budget conversion uses an odyssey pc1500!!!
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
