Old 08-08-2010, 11:52 AM   #20 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Arragonis View Post
Obviously completely barking mad.
In this design, gravity is perpendicular to the force executed on your model, and you'd need to compensate for the associated drag.
Tilt the set-up 90° so the test subject hangs vertically from a scale.
That way, you'll eliminate gravity as a disturbing factor and you'll measure both forces (gravity and drag) in a linear system with only one variable.
Far easier ...
The Following User Says Thank You to euromodder For This Useful Post:
Arragonis (08-08-2010)
