Thread: 6th gear swap?
Old 08-09-2010, 12:18 PM   #1 (permalink)
redpoint5
90 day: 29.78 mpg (US)
6th gear swap?
I drive a 2006 Acura TSX 6-speed manual, and the car has among the lowest Cd I've seen (.27). When I bought the car, I was thinking that with 6 gears, the top gear would be very tall and good for highway travel. The reality is that it's geared very low and has close ratios. At 70mph, I'm doing 3000RPM, which seems a bit high.
Is it possible to swap out only my 6th gear so that I can accelerate quickly in the first 5 if I wanted to, but shift into 6th to cruise efficiently? If it's possible, how difficult would the job likely be?
At 70mph, what RPM are you running?
