Old 08-09-2010, 03:45 PM   #6 (permalink)
ChazInMT
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Couple of things I notice here.
1st, You need to make the vehicle much smaller to get any decent result. Flow illustrator will use the sides as physical perimeters and you won't get an aero picture of your car which is accurate...unless you want to know how your car performs in a 12 ft tunnel with a 60MPH wind blowing through it.
2nd, Dr. Chernyshenko is pretty specific that the RE be set between 100 and 1000 for cars. From the looks of these you have it in the 3000 + range. (Be sure to push the Submit button after changing the parameters)(Not that I've ever forgotten to do this)
Here is a beetle at Re=750 dt=.02, the dt tweak lets the flow settle quicker, so at the end of 10 seconds, you have a good idea of steady state conditions. Even this car is a bit too big for this application. I'd have been better off making it 2/3rds this size.
Also, when your "Model" is smaller and pushed to the left, you get to see the wake in back which is the real key to all this effort here.
Hope this helps!
The Following User Says Thank You to ChazInMT For This Useful Post:
Arragonis (08-09-2010)
