Old 08-10-2010, 11:52 AM   #1 (permalink)
SamuelClyde
Vacuum Gauge plumbing
Hey guys, I've just received my TIM Vacuum Gauge and I'm looking at where to plumb it on my 1998 corsa 1.4 16v automatic.
I found the hose going from my manifold to the MAP (manifold absolute pressure) sensor and this is the perfect tube for tapping into (size and location) but would plumbing my T-peice into here cause any problems with the MAP sensor? and would I get an accurate reading from here?
The only other alternative is the other vacuum pipe which has the EGR valve connected to it, and I'd rather not plumb on there because of the much the EGR kicks around.
Thanks
