Thread: 6th gear swap?
Old 08-11-2010, 06:59 PM   #5 (permalink)
some_other_dave
"Mista Bone" on the Honda boards is regarded as a D-series transmission guru. He tells me that you cannot swap the drive and driven gears to give you "inverted" gear ratios. Which is too bad, because an inverted 2nd gear sounds very attractive for MPG...
-soD
The Following User Says Thank You to some_other_dave For This Useful Post:
cfg83 (08-11-2010)
