I like the Kamm you built and think I will try to build a template for my car this weekend if the weather is decent. You have the benefit of having a hatchback so attachment is a bit easier. The route I will be going for final attachment is going to be double sided foam tape and adding tabs for attachment otherwise the template should turn out like your pre-bent kammback.
 I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
