Old 08-13-2010, 11:56 AM   #7 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Originally Posted by RobertSmalls View Post
There is always the coolant circulating type: Amazon.com: Kat's 13100 1000 Watt Alumininum Circulating Tank?
hi, can these 'pipe mounted' circulators ensure that the coolant in the block is heated? If so how do they bypass the thermostat?
If they only heat the coolant from thermostat to rad, then they wouldnt speed up the time for the block to get to operating temp?
With a block heater as the OP has suggested, you'd be heating what needs heated?
