Old 08-13-2010, 03:19 PM   #10 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Originally Posted by RobertSmalls View Post
You install it on the engine side of the thermostat, e.g. in the heater bypass hose. Downside: it circulates the heat through the heater core if you parked the car with the heater on. You'll spend electricity heating the cabin, not just the engine.
Edit: aw, you beat me to it, Daox.
thanks for the info fellas
It makes more sense now-but i see the issue regarding cabin heating.
Would it not be possible to insulate the block to minimise the time and amount of elec required to heat?
Essentially similar ro a thermos flask-the blok coolant would remain warmer for longer?
I have no idea how you'd do it-just puttin a possible solution out there that may cost less than a second block heater?
